Good morning Overclockers.
I've seen dozens of threads from people talking about replacing the rubbish Eheim 1000 that comes with the Reserator 2, and now I find myself in that same position. Nobody ever seems to talk about the how of the problem though, just the with.
After a good couple of hours of fiddling with it, I can't figure out how to remove the old pump, or even get a decent look inside the thing to see how it could work. The pump is at the bottom of the water well, screwed in where my screwdriver can't reach. Taking the screws off the underside of the well itself doesn't release the pump enclosure, but it does allow it to move a bit. There's a black bar going across the underside of the unit to where the power and PC cables plug in - I've tried to remove that, but two of the screws have become worn and will need a specialist tool to remove. Or some super glue and a ruined screwdriver.
Anyway, my specific questions:
But my main issue is how to get the old pump out - if I could do that, I could easily just look at the existing setup and make a decision from that.
Thanks in advance for any tips you guys have! I'm quite far out of my depth here, so I'm running on fragmented forum advice already.
- I've read that I can have the old, broken pump in parallel with the new one. Is this true? Some people said the old one will hinder the flow.
- Can I have the new pump somehow inside the enclosure while it's running parallel?
- Does a new pump come with all the bits and tools I'd need to attach it in parallel? If I've understood the guide, i'd merely need two straight barbs. I'd imagine it's just a case of cutting a hole somewhere along one of the tubes and putting the pump between them - the reserator would remain unpowered and the old pump wouldn't do anything, but the radiator will continue to remove heat from the liquid...
- Lastly, if I can manage to remove the old pump, I'd much rather have a new one which fits in the enclosure. Does anyone know which pump would be best and fits in the Reserator 2 reservoir?
