i ordered the svc goldengate 30 for 19.99 and some articsilver2 for 4 bucks insane prices on both!
i took the 7k delta off my thermoengine and installed it on the gg.then i lapped the sink in with 600,800,and 1000 grit sandpaper.i then applied the arctic silver per the instructions on their page.installed the sink and the results were good.
running a 1.33tbird at 2.08 volts clocked to 1.56 yeilded temps that match my system temp or beat it a few degrees!at full load running prime95 its about 8-10 degrees cooler than my delta thermoengine combo was.im very pleased with this purchase considering the thermoengine was more expensive(cant just throw money at something and expect maximum returns without research).ill take the 30cfm fan and use the thermoengine on my wifes duron ([email protected]) may reach a ghz there now.
im going to try some higher clocks later before it was not stable in applications at 1590 but would load windows sometimes it would lock though.update later
i have the delta blowing on it.is this best with this sink?
the arctic silver application page said that over 24 hours the temps will drop 2-3c once the silver has bonded can i expect this is it true?
thanks
thanks
