To run it without a motherboard, use a small piece of wire, small paper clip, etc to connect the green PS_ON wire to a black ground wire. If it doesn't start up, or acts erratically, try loading it with a couple old hard drives.
Though, you did bring up something important: Minimum load. Those old hard drives probably will be required for the PSU not to act weird. IIRC, typical computer PSUs need a minimum load to function normally.
