- Nov 1, 1998
To celebrate the launch of their latest line of power supplies, Rosewill is giving away two 80-Plus Platinum Certified Fortress PSUs. Entering the contest is extremely easy, follow the simple steps at the bottom of the article.
Prizes
Grand Prize: Fortress 750W Power Supply
One lucky winner will receive an 80 Plus Platinum Certified 750W Fortress Power Supply, which is available for $139.99 on Newegg.
Features (Courtesy Rosewill)
Second Prize: Fortress 450W Power Supply
Another winner will receive an 80 Plus Platinum Certified 450w Fortress Power Supply, which is available for $99.99 on Newegg.
How to Win
In order to enter the contest, all you have to do is the following:
Told you it was easy! Best of luck to all of our fans who enter and stay tuned for more great contests in the very near future. Thanks to Rosewill for sponsoring this event.
Prizes
- 80 PLUS PLATINUM Certified
- Continuous 750 W @ 50 °C
- All Japan capacitors
- Single strong 12 V rail
- SLI & CrossFire Ready – 4 x 6+2pin Connector
- 1x Silent 135 mm Fan with Auto Fan Speed Control for better silence
- Active-PFC with auto AC-input voltage adjustment(100-240 V)
- Special Black Coating Housing
- Mesh sleeving on all cables for easier cable routing and better ventilation
- Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit Protection provide maximum safety to your critical system components
- Safety & EMI Approval : cULus, FCC, CE, ROHS
- 7-year Warranty : One to one replacement
- Continuous 450 W @ 50 °C
- SLI & CrossFire Ready – 2 x 6+2pin Connector
How to Win
- Visit the Overclockers.com/Rosewill Contest Page on Facebook
- Click the "Like" Button above both the Rosewill and Overclockers.com logos (if you are already a fan, skip this step)
- Enter your email address, then agree to the rules
- Hit "Submit"
