- Jan 7, 2005
- Dallas, TX
It takes a lot of me failing on my own before I actually will admit to not being able to figure it out on my own and post asking for help, so please be gentle lol
I purchased this server which seems to be great so far, except for one very important aspect... I can't get ANY of the SAS or SATA ports to work. (note: the sas drive cage with the 2 sas drives and the rackable systems backplane are not pictured in the link).
When going to install any OS, I am not given any options for available drives. I have even went as far as to use one of my own known-working drives, with a known working SATA cord that I own, and even powered it using a separate PSU. This would theoretically isolate any problems to be the motherboard itself. The thing is though, I was able to boot from a SATA CD drive, so I think the motherboard's SATA is working in the least
Through lots of googling and guess work, I was able to determine with a lot of uncertainty that the chipset for the board is an nForce Professional 3600 series. According to the available drop down menus on the site, it looks like the most recent version of Windows Server supported is 2008. I'd really like to install Windows Server 2012 if possible, and anecdotal evidence suggests this may be a possibility. When going directly to the manufacturers website though, it does look like drivers for windows 7 64 bit are available.
Please note that I have saved the drivers and loaded them during my attempts to install an operating system, and never has a drive shown up. What I'm trying to install (for now) is Windows 7. I have tried both the SAS drives and my own known-working SATA drive with my known-working SATA cable and a known-working power supply unit as well as trying to run it off of the servers own PSU.
I have also enabled and disabled raid on the motherboard. When entering the SAS configuration utility, it does not identify any drives when they are plugged in.
Here is where things get exceptionally confusing for me. The included cables with the SAS drive cage/backplane are definitely serial ATA. They are labeled as such, and they look identical to my existing SATA cables. This makes me think maybe the cables are of the wrong type. This also makes me think maybe the SAS backplane is actually converting from SAS to SATA?
I can't figure it out, but in my searches I've not found any SAS cables that look like the end is compatible with a SATA cable. This remains to confuse me, since the ports on the motherboard labeled SAS are clearly interchangeable with the SATA ones. If they weren't labeled, I would be unable to distinguish between the two. The normal SATA cables fit the SAS ports on the motherboard, as well as the ports on the rackable systems backplane.
Still, none of this explains why I can't see my known working harddrive/sata cable/psu combo on the install. Even if the drives or sas controller was shot etc I should still see my known-working drive.
What I've tried/observations
*Tried drivers from nvidia and mobo manufacturer, both not successful
*Enabled raid/disabled raid
*reset BIOS
*trying to install windows 7 pro 64 bit for now
*tried installing from a usb stick instead of disk
*noticed there is an empty 4pin power header on the mobo. i filled it with the matching 4pin header on the PSU... it doesn't even attempt to power on in this configuration. fortunately it doesn't seem like attempting this has done any harm, as after unplugging the header the system boots fine
*booting from USB works great, i've booted a live linux distro as well as trying to install windows via a usb key
*tried loading the SAS drivers during the install screen, the SATA/IDE drivers, the SATA/raid drivers, none have any impact
*observed if RAID is enabled, the available drivers for RAID will either show up or disappear in the installation as an option to install. this further supports the idea that the motherboard/sata is functioning
*i can't find any information at all about the sas backplane online apart from an ebay listing with a worthless description
Any ideas what I'm doing wrong here? If it's something really stupid I'm totally cool with that, I can get this behind me and move on lol. If you need any additional info please feel free to ask, I'll be glad to provide it.
*reset BIOS
