- Nov 19, 2004
- Albuquerque, New Mexico
Well as some of you read my build had overheating probems, well after hours of chin scratching I lay the mobo flat on the table ad get up close and personal with the CPU and heatsink, turns out the fan controller temp scensor was holding the heatsink about 1/2 a mm off the CPU on 1 side of it, so I took HS off, replaces thermal grease removed cesncor screewed HS back on and no space Turn on we are getting 27C!!
Now for the Hard drive, we got 1 SATA 150 gig drive, this is my first experience with SATA so im having some problems... it is on a ASUS A8V Mobo on Array 0. On bootup it detects it and is set to the 3rd boot device in BIOS but when I go to install windows it says No Harddisk found, blah blah blah setup cannot continue check this check that blah bla press ENTER to restart, I fiddled with the BIOS for about 1.5 hours before I decided to call it quits for the night and come here... thanks a bunch!
