Since the computer was fine (I assume while playing this game) and suddenly the problem occurred, I don't see how your combination of game, card and monitor would be bad - assuming the hardware is working properly.
At this point, there is no way to tell exactly what the problem is. It could be the monitor, your card, a cable or the power supply. Is your graphics card driver current? Did you recently update it? Did you recently update the game?
Does it happen with any other program or game?
Did you try power cycling the monitor (instead of rebooting the computer)?
Start with the easy stuff first. Make sure both ends of the graphics cable are tightly fastened. If tight, you need to try a different monitor (hopefully with the same resolution) on your computer and see what happens. And it would be good to swap in another capable PSU to eliminate power as the problem.
Thanks for reply.
Display adapter driver version 25.21.14.1917 (I see this isn't latest driver)
This only happens when I play Starcraft 2 and Diablo 3.
I cant't see anything, so I don't think I can do anything?
Everything is tightly fastened.
And unfortunately, this is only monitor that has only this resolution. And this is only monitor that I have.
Forgot to write PC Spec, here you go:
- Thermaltake Core X9 (CA-1D8-00F1WN-00
- Corsair RM Series RM850 PSU
- Intel Core i5-4690 Processor (6M Cache, 3.5 GHz, up to 3.90 GHz)
- Asus Z97-PRO (Wi-Fi AC) Motherboard
- 2x Corsair CMX8GX3M2A1600C9 8G (2x4G) DDR3-1600 Memory
- ASUS STRIX-GTX970-DC2OC-4GD5 GeForce GTX 970 4GB 256-Bit GDDR5
- ASUS ROG Swift PG27UQ Gaming Monitor – 27” 4K (3840 x 2160), 144Hz, HDR, G-SYNC
- Windows 7 Ultimate 64bit (ENG)
Does the same thing happen when you are playing other demanding games? Sounds like it could be some kind of thermal issue either with the CPU/motherboard or the card. How far into the game time wise does this seem to happen? Doe it happen at the same point in the game every time? Is it repeatable in this sense?
I would do some stress testing that doesn't use the video card much (like Prime95) and then some that doesn't use the CPU much (like Heaven). That might help you distinguish whether the problem is video card related or CPU/motherboard related. Are all the fans spinning on the card during hard game play? Is the card's heat sink clogged with dust?
With a video card that old it could have developed some loose solder traces from years of temp change contraction/expansion. There is a process of "baking" in an oven that can fix this.
Remove and wipe the drivers and do a fresh install of the latest drivers. There are utilities out there that will help you do a complete wipe of the drivers.
Also try some basic thing like checking for loose monitor cable connections or even swapping out the cable. Chances are it's something with the video card but doesn't hurt to try some of these other basic troubleshooting measures that are free or at least cost effective.
Other than these measures I have outlined it boils down to swapping out parts.
Thanks for reply.
This only happens when I play game, which are: Starcraft 2 and Diablo 3 (This is only games that I play).
The problem never happens when I don't play games.
The funny thing is it has working fine until few days ago.
Every cable is tightly connected (I use DP cable for it)
- Thermaltake Core X9 (CA-1D8-00F1WN-00)
P.S:
I just updated to latest nvidia driver.
