Hi all!
A quick heads up for these fans... They are unreliable! Your probably thinking, "well, it is to be expected that one fan is going to go". Well, do I have news for you my curious friend. I had 3 of them in my case...
Ok, let's start from the beginning. I wanted absolute BEAST fans, I didn't care how loud, I just wanted fans that would get the case temp as close to room temp as possible. I installed 2 on the H70 rad and one in the intake. I was planning to install another as intake and 2 on the top after using 2 fan adapters. I was that impressed with there performance.
After a while, within a few weeks, the back fan started to click, I thought that it was odd but decided to ignore it. The clicking stopped and I was able to handle the noisy movement of the blades cutting through the air, but that clicking, that annoying clicking was back. It continued for weeks, but finally stopped. The back fan was causing it.
Everything was great for a few more weeks but finally the front fan started to click, and IT WAS BAD!!! It would click at volumes similar to actually clicking your fingers, now imagine that, constantly for hours (do it! Click your fingers and feel my pain lol). I could handle it and would occasionally block 1 air filter which seemed to fix it. It was good again, for a few days this time, then the back fan started!
To make matters worse, all 3 started to click! I couldn't take it, I... Well...
Out of rage from having people coming into my room at night time asking what the sound was, grabbed the fan, snapped each blade, threw it in the bin, and now I am left with no Kaze 3000 fans, cut my fingers as I snapped the intake fan while it was running, and the case is slightly scratched, damn strong fans I tell you.
To the point, they failed for me. All 3! That is bad, so you have been warned, and I need new fans. What should I get guys? I still want the great air flow and don't care about the noise, I was going to order the 1900rpm slipstream fans but I am worried they will click :S I have lost faith in Scythe, do you think I will be ok with the 1900rpm slipstream fans?
BTW, before you mention the fit I had, yes. I have anger issues, it isn't the first time I have completely destroyed something that has frustrated me... Poor poor PS3 (RLOD), this anger problem is costly =O
