Sen's 2400+ (35W) Mobile Review / OCing
Sentential
Contributing Member
Knoxville, TN
The time has come.... I have my new CPU in my hot little hand. Im gonna finish Benching my Tbred here shortly... pics of my system... both CPUs and benchies will be here shortly:cool:
Sentential
Sentential
Contributing Member
Knoxville, TN
Tbred Benchmarks
1800XP+ (246.6 x 9.5) @ 1.75v
Prime Stable?: NO... get random errors not associated with RAM. Assuming CPU limit reached
Memtest86 Stable: Yes
3dmark stable: Yes
Radeon 9800PRO
Clock: 423
Mem: 375
RAM Timings: 2.5 - 3 - 4 - 11
_________________________
*3Dmark01SE* (Catalyst 3.5)
Compare URL
This project can not be published due to detected CPU speed variation.
More information...
System Configuration
Operating System Microsoft Windows XP
DirectX Version 9.0
Mobo Manufacturer http://www.abit.com.tw/
Mobo Model NF7-S/NF7,NF7-V (nVidia-nForce2)
AGP Rates (Current/Available) 8x / 4x 8x
CPU Unknown 2343 MHz
FSB 245 MHz
Memory 512 MB
Graphics Chipset ATI RADEON 9800 PRO
Driver Name RADEON 9800 PRO
Driver Version 6.14.10.6360
Video Memory 128 MB
Program Version 3DMark2001 SE
Resolution 1024x768 32bit
Texture Format Compressed
FSAA Disabled
Z-Buffer Depth 24bit
Frame Buffer Double
Rendering Pipeline D3D Pure Hardware T&L
Detailed Test Results
3DMark Score 18915 3D marks
Game 1 Car Chase - Low Detail 254.6 FPS
Game 1 Car Chase - High Detail 86.4 FPS
Game 2 Dragothic - Low Detail 365.5 FPS
Game 2 Dragothic - High Detail 191.3 FPS
Game 3 Lobby - Low Detail 225.5 FPS
Game 3 Lobby - High Detail 100.3 FPS
Game 4 Nature 145.0 FPS
-Sisandra-
Memory: 3552 MB/s (INT) | 3271 MB/s (Float)
Arithmetic: 8947 (MIPS) | 3690 (MFLOPS)
Multi-media: 21482 (it/s) | 21629 (it/s)
-Aquamark- (Catalyst 4.4)
Run0:
DisplayWidth: 1024
DisplayHeight: 768
DisplayDepth: 32
AntialiasingMode: 0
AntialiasingQuality: 0
AnisotropicFiltering: 4
DetailLevel: 4
AvgFPS: 43.533512
MinFPS: 12.795290
MaxFPS: 119.000000
AvgFPSRender: 60.281570
AvgFPSSimulation: 162.892090
AvgTrianglesPerSecond: 13104987
MinTrianglesPerSecond: 1972012
MaxTrianglesPerSecond: 33930191
AquamarkScoreRender: 6027
AquamarkScoreSimulation: 8145
AquamarkScore: 43533
__________________
*3Dmark03*
http://service.futuremark.com/compare?2k3=2486134
General Information
DirectX Version 9.0b
AGP Rates (Current/Available) 8x / 4x, 8x
CPU AMD Athlon(tm) XP/MP/4 2343 MHz
FSB 245 MHz
Memory 512 MB
Display Information
Driver Version 6.14.10.6436
Driver Status WHQL - FM Approved
Video Memory 128 MB
Core Clock 423 MHz
Memory Clock 375 MHz
Sound Information
Sound Adapter Driver Name
Sound Adapter Driver Version 6.14.431.0
Benchmark Settings
Program Version 3DMark03 Revision 4 Build 0
Resolution [email protected] bit
Texture Filtering Optimal
Pixel Processing / Antialiasing None
Post Processing false
Vertex Shaders Optimal
Main Test Results
3DMark Score 6338 3DMarks
CPU Score Not enough CPU tests run
Game Tests
GT1 - Wings of Fury 200.5 fps
GT2 - Battle of Proxycon 42.3 fps
GT3 - Troll's Lair 37.6 fps
GT4 - Mother Nature 39.8 fps
*Voltages*
-12 = -12.11 ~ -12.03 (load)
+3.3 = 3.28
+5 = 4.97
+12.00 = 11.92~11.85 (load)
-5 = -5.04
Unfortunatly I gotta head out to a job interview.... Once I get back Im gonna stap my Barton in:cool:
ares350
when you put the mobile in, give us details, like if you did the L12 mod at all(and which one), burn in procedure you took...
every step. itd be really helpful to see what an experience over clocker does.
obsolete
MN
What the heck is this crap? This is the most deceiving post I have read in a long time. Burn the Tbred, pop that 2400 in & get to it!!!!!! :mad:
Slacker.. :p
:D
Sentential
Sentential
Contributing Member
Knoxville, TN
Will do..... my tbred is L12ed (thnx for reminding me), so will the Barton. However... my mobo is completely stock. No volt mods.
Using an SP97 and a SF2 to cool it.
Ill have alot of pix shortly
Slacker.. :p
:D
Totally weak..... I got the job but now I gotta run outta the house and get a drug-test..... GOD DAMNIT!!!! MUST OC NOW!!!
Sentential
Sentential
Contributing Member
Knoxville, TN
First set of pictures are in. Sorry about the re-size. Im using some cheap HP camera...its better than nothing IHMO.
My Desk:
(CPU is under my monitor.... so is my GameboySP w/t the original Tetris)
My Desk #2
My PC <The Wailing Banshee>
Banshee #2
_____________
Note that the Videocard is cooled by a TMD Fan / SK7 Combo. And *ESPECIALLY* Note my Mofset coolers.... they are as tall as my SP97/SF2 put together:eek:
Next on the extravaganza is pics of my BIOS screen / settings and the 2400+ results @ Tbred speeds.
_______________
If you guys have *any* and I mean *any* questions.... lets hear em.... just as long as its not: "Why the hell are your pictures soooo blurry??:p)
-Sen
ares350
I cant see the photos :p
but I dont care, just give details, L12 mod, bios settings to begin with, burnin procedure if you do one, ect, and of course final results.
Sentential
Sentential
Contributing Member
Knoxville, TN
yea... Im workin on it.. Thankfully I recovered my BIOS:D
However I will give you the scoop thus far (blew out my internet connection on *my* PC)
The xtra cache brought me to 19,578 at the same speeds.
At 251 x 10 my score went to 20,271:cool:
oc_byagi
Sunnyvale, CA
sorry to be asking over and over but..... which holes were connected for the L12 mod on mobile 2400+? (if you have already done it)
Sentential
Sentential
Contributing Member
Knoxville, TN
L12 mod
NP at all!!!... ask away.
Once I get my internet connection back Im gonna post my final results.
They arent exactally what I had hoped for...but I still break 20k (On WinXP mind you;) )
Sentential
Sentential
Contributing Member
Knoxville, TN
Stable v-core @ 246 x 10 is now 1.75v. Im gonn burn this chip in and see what she can do...
More pics are on the way:cool:
Sentential
Sentential
Contributing Member
Knoxville, TN
BIOS screens (as promised) *Using Tictac's D22 Alpha Betaking 2 Turbo
**However, keep in mind that I tried to do a vdd mod once I got my 2400+... it didnt go well. I nearly lost my board and it refused to post and locked up.**
1800+
2400+ (Part 1)
2400+ (Part 2)
Still getting this stupid f*in Temp File error over 246 :mad:
____________
BTW thnx pershoot!
-Sen
Sentential
Sentential
Contributing Member
Knoxville, TN
:mad: Still having issues with cold-booting with voltage over 1.85v
..Spoke with PMS fishy.. he has no issues using official D21 BIOS. Im gonna give that a shot
pershoot
NYC
it does that (or will just stay stagnant on the win screen (if u run windows.. bar wil keep moving but wont load). this was more prevalent with the 35w then it was for my 45w (but similar types of traits observed here and there). give it time. after enough nudging it will accept the voltage and go higher.
you will probably come back to or finish up on d22a1bkr2 (i switched between d22 3dfire (my old 2500+'s bios) and d22a1bkr2 a few times while OC'ing the 35w (even tried d23 subzero and d23 3dfire too for kicks (d23 didnt work very well for me on both cpu's)).
good luck man:)
CandymanCan
Disabled
Woodbridge, Va
So umm what youre complaining that u cant get over 246fsb ? Gimme a break, just lower the fsb to like 240 and raise the multi i wanna see how far this cpu can go not ur Fsb.
