Iv been debating this for a while, i know the mobo temps arnt that accurate on these boards, but am debating whether the 948U would lower my temps i have. Im currently getting 45 idle at 1.55 volts, with my hyper 6 and stock 32cfm fan. I heard that the xp-90 and 120 dont perform well on the a64 as they dont bolt down tight enough. If these two do not bolt down well to the cpu then im thinkin my 1.1kg hyper6 would be worse :s
Shall i stick with the hyper 6 or go with the SLK-948U?
Thanks
Thanks
