Hi people, I'm new here and am looking into WC my current setup. This will be the first time I WC a PC. I have goone through the stickies here and on other forums. Have a pretty good idea as to what I am going to be doing but have run into a problem with choice of radiator.
Due to space constraints I will be using a slim (max 35mm thick) 120.2 radiator in a single loop to cool an i5 2500K. My problem is which radiator to use. Frozencpu has got 3 that I can use.
1 XSPC RS240 Dual 120mm Low Profile.
http://www.frozencpu.com/products/1...le_Radiator_Rev_2.html?id=AgD2yRhn&mv_pc=4938
2 Black Ice GT Stealth 240 Radiator
http://www.frozencpu.com/products/4..._Radiator_-_Black.html?id=AgD2yRhn&mv_pc=4415
3Magicool Extreme Dual 120mm Radiator - Slim Profile
http://www.frozencpu.com/products/1..._LC-RADI240.html?id=AgD2yRhn&mv_pc=4941#blank
I've been able to find out that the xspc is a low fpi radiator and the black ice is a high fpi radiator. Haven't been able to find any info on the magicool one though.
I have 2 questions 1) does anybody know where I can get info on the magicool radiator, such fpi and the likes and 2) which radiator would you recommend to use.
As I said this is a simple loop to just cool the CPU.
thanks
thanks
