- Jan 11, 2012
- North Carolina
I love that paint.
That's it, I'm learning how to powder coat!
I haven't actually powder coated myself, but it's not a very difficult process.I love that paint.
The first thing you need to do is find an oven large enough to bake your powder coated items at 400ºF. The second is to make sure you have a very even coat of powder over your piece... it's electrically charged particles of powder clinging to a grounded piece of metal, so if you over spray the powder, it just builds up and will become a big drip or smear when you bake it.
You can buy a cheap entry-level powder coating gun/kit from the Eastwood Co. online, then buy whatever powders you want to from various distributors (can buy as little as 1lb at one time, up to 100's of lbs). After that you just need to get yourself a cheap electric oven from a used appliance dealer or pick one up from the curb, yank out all the racks in there, and make something to hang parts from inside the oven. This'll work just fine for small parts, but it will take practice to coat things right and bake them right. For this reason you want to have an oven with a properly calibrated and operating temperature control, and an accurate egg timer. -- And DO NOT USE YOUR HOME OVEN. Once you bake powder in that one oven, you don't want to be baking food in it afterwords.
For anything bigger than what fits inside an oven, I would stick to having a professional metal-finishing company doing it for you, simply based on the skill it takes to evenly coat larger pieces, and the equipment/size of oven needed to bake those pieces once coated.
Another important thing to take into consideration is metal prep - usually a shop will sand-or-bead blast your pieces before powdercoating because you absolutely cannot have ANY oils on the surface of the metal, otherwise the powder will not stick or will bubble in that area once baked.
Hope that helps.
Thanks for the info Sneaky. I work in a body shop and co-own a smaller restoration shop, so I am familiar with prep and painting. I didn't know how powder coating worked though. Definitely didn't know about baking it, though I'm sure that makes it tough and durable. Would a paint booth with integrated heat lamps work for baking larger things? Just curious, I probably wouldn't coat anything too large anyway.
If you can hold an even 350°-400°F they'll work.
Needs to be held for about 20 minutes, maybe a bit more depending on the part.
Not painting the keys... just the frame around the keys. Don't want to alter the functionality of the keyboard at all.I'm looking forward to this.
My PS/2 keyboard may not be mechanical, but it's just as loud and the same shetty gray colour your keys are
Wouldn't mind seeing how they turn out.
OhNot painting the keys... just the frame around the keys. Don't want to alter the functionality of the keyboard at all.
I as well think it'll look good and provide a good contrast. I mainly just wanted to do something outside of a stock grey keyboard.Oh
Actually, that'll look real good. Grey/white keys with green frame
It has been tested and proven in temperatures from -30°F to 200°F.
Good to see you back man. I haven't posted on here in years either. Started lurking around a few weeks ago and just saw your thread today.
