- May 27, 2001
- San Diego, CA
OK. I have just about ready to buy my water setup. I am going to get the Maze2-1 water block for my 1.4ghz athlon at 1.6ghz as i found out that this is better than the one at overclockers hideouts blizard kit. For a radiator I am also going to get the danger den cooling cube unless some one else says otherwise with good reasoning. Now that i think about i am going to get that top of the line danger den kit. My only gripes are 1: is the eheim 1260 pump good enough or should i get the resovoir at overclockers hideout. what id the benefit of a reovoir over a pump if any?(I know nottin bout pumps) and 2: what power supply do i need to get for the 156 watt peltier cuz i already have enermax 430 watt?
For setting it up i gots a lian-li pc70 case on the way. Should the radiator be up top and the pump on the bottom?
Shoot all the holes you want to into this one please.
