- Jul 30, 2014
Hi guys,
After getting my DM200 flashed with openwrt I put in all my ISP settings but there was no "switch" option in the menu did a google and one post on the openwrt forum made mention of setting the vlan in the custom interface area which I did. The router then wouldn't connect to 192.168.1.1
Openwrt has a fail safe by setting pc ip subnet to get back in I tried this and it didn't work. Another post said to telnet in then issue commands to force the router to run again, can't telnet in since the connection is rejected so its not possible to issue commands.
I honestly just want the damn thing back to stock since its 5am and this is driving me crazy. Is it even possible now or am I bricked??
I thought if it was possible to tftpd the stock firmware but it sits there and does nothing no errors and no movement, unless im using the wrong file??? (using the firmware img file found off netgear website) though I noticed on the dm200 page on openwrt webpage there is a link to a gpl file?? not sure if thi has what I need or not as 70$ cell credit down the toilet trying to get the file so I don't even know if thats what I need or not to fix my issue think I have just wasted $100 bux on a brick
If anyone has ideas on how I can if its even possible to fix let me know please.
Cheers,
Bandit
Cheers,
Bandit
