- Jan 10, 2012
does anybody offer a fairly complete starter kit of tooling for rigid tubing?
what's actually needed?
The best kit I know of ...... comes in a couple of different configurations this is the biggest kit.
http://www.performance-pcs.com/mons...eluxe-bender-kit-1-2-x-5-8-16mm.html#Features
Sounds good, I just know how often you're swapping parts. If things will remain the same for a while then I don't see any issue. I actually like the way rigid tubing looks, I just am always swapping parts around.Manny, I'm thinking my gaming rig is as far as it's going to go, a 4790K and 2 980ti's should carry me quite some time. the other rigs will all remain soft tube and quick disconnects to the loop.
Caddi, you sure you want to use rigid tubing? You swap parts around all the time, just ask Bassnut about the endeavors of rigid tubing and changing parts.
I've been hearing about some are getting cracks on their bends. Best bet in this case would be to try and use fittings for the angles and use the rigid tubing for straights only.
