Hello everyone; this is my first post. I am brand new to overclocking. I have been tossing around the idea of upgrading my CPU for a while now (I have FX6300), but quickly discovered the FX8350 is the only drop-in upgrade I can put in my board (not enough MB power for 9590). So instead of shelling out for a new MB as well, I figured I'd try OC'ing for fun. If I fry the thing, I'm no worse off since I was thinking about upgrading anyway.
Anyway, to get started I picked up a Noctua DH-15 and managed to stuff it into my case with a bit of banging on the side panel. On the stock cooler I ran around 28-30C idle, and on the Noctua it now jumps around 17-22C idle. This confuses me though, because the ambient temp is 25C. This just isn't possible...how are my temps being reported this low, and should I stop trying to push the CPU if I can't get accurate temp readings?
All I've done so far is change the multiplier, and disabled the PWM stuff. The basic idea is keep increasing the multiplier until unstable, then increase the voltage to compensate, yes?
Thanks for reading my ramblings.
CPUz / HWINFO:
CPUz / HWINFO:
