yep, should fit just fine. If the holes don't line up you can always attatch it with a dab of super glue on the edges. The super glue will of course be rather difficult to remove in the future. Make sure u use a little thermal paste too for the best results.
Ok can you recommend a chipset cooler that will fit? im scared to do things like that Im only 19 and i dont have all that much money just in case I jack it up .
