- Mar 7, 2002
- San diego or UC Davis
I've searched the forms, and I haven't found any hard data on if blowing or sucking is the best way to cool a radiator. I would like to keep the radiator inside the case, while blowing fresh air onto it. I feel this will cool it better as opposed to sucking the air away which in my oppinion is too passive.
I am aware that this will end up blowing hot air into my case, so I think I will make a duct from the radiator directly to a fan blowing out. If I do it right It should keep any heat from the radiator from leaking into the rest of the case. I'm sure someone has done this before.
Is it worth it to do this, or should I just stick to sucking the air away from the radiator.
Just looking for input, thanks guys/gals.
