First of all fear my mspaint skills. Yes I ride the shortbus.
the yellow area is about 1 inch across on each side, the black lines on it is venting. The blue dots are LEDs, the whole area there is only about 1.5 inches deep (its inside the front bezel). What Im trying to do is put some kind of half pipe to cover the corner so that the light is sorta evenly reflected outa the entire vent, and only can escape out the vent.
Anyone got some suggestions? Id appreciate it thanks!
Also, maybe it would be better to use glowwire? How bright is that stuff?
EDIT: pic should be there now, I hope...
