- Dec 27, 2008
Well, I'm largely done with my dabbling in all in one closed loop water cooling. I had to try it anyway, right? But after trying four different units and having to return three of them for various problems (mostly pump related) I decided to go back to my trusty Noctua NH D14 but with a different twist, you might say.
To begin with, I found that none of the AIO water coolers gave much improvement in temps over the Noctua. The best one was the Coolermaster Nepton 280L that gave about 4c better temps than the Noctua air cooler when both were run in stock conditions. The Nepton 280L was considerably noisier than the Noctua, however. Unfortunately, it also developed an annoying high-pitched pump squeal so I RMA'd it. But I digress.
Last night I swapped out the stock Noctua D14 fans with more powerful ones.
To start with I removed the stock 120x25mm fan in the front and replaced it with a Delta AFC1212D-PWM (120x25mm, 3400 rpm, 10.9 mm-H20). I left the stock 140x25mm Noctua stock fan in the middle between the two halves of the heatsink. This did not seem to make any real difference in temps.
Next, I moved the Delta to the middle position between the two halves of the heatsink and strapped a Silverstone FHP141 (140mm x 38mm, 2000 rpm) to the front of the cooler. The thick Silverston fan made a difference of 3c in idle and max temps. For $17.00 this dual ball bearing fan rated for 150,000 hr. of service has to be the best fan buy I am aware of. http://www.newegg.com/Product/Product.aspx?Item=N82E16835220056
I should say that when all fans (case and CPU cooler) are running at max speed there is plenty of noise but I have all of them on a Sunbeam Rehostat Extreme fan controller. When I turn them down to just over stall speed the system is very quiet.
There is about 2c difference between quiet fan setting and max (87c-85c) at this stress level. And yes, you loose some fan RPM with the rheostat style controller but I tested the difference and there is only a 4% loss in fan speed.
Also, I was able to use the stock fan clips from the Noctua fans on my replacement ones. The 140mm Silverstone fan has 120mm mount holes.
Here are some pics:
Here are some pics:
