- Mar 4, 2004
- Fort Worth, Texas
Okay, I've had this problem for a while now.
My setup is
Soyo Ultra KT333 Motherboard
AND 2600+ Thourghbred
WD HD
Mad Dog Gfx Card (NVIDIA CHIP)
This is a really really -REALLY- strange problem we've been having for a while now, this comps not 3 months old.
It'll 'reset' as if you hit the reset switch on the case....
Appears to do it randomly but not too often (once every 2-3 hours or so?)
You could be browsing the net, playing a game, doing taxes, whatever and it'll do it. It also likes to do it when waking up from sleep mode.
I've tried the following to isolate the problem
* swapped the RAM with another chip
* Unplugged both DVD and CD-RW drives powercable (no power, no bios detect)
* checked for IRQ conflicts
* checked to make sure motherboard doesn't short against case, swapped
* switched power supplys
I'm about damn out of troubleshooting tips.
(!! ANSWER FOLLOWING QUESTION IN A REPLY) Could it be Windows Server 2003 problem?
I ask this because it just reset a few minutes ago and when it restarted it booted up normally but in 16 colors and I looked at display propertys and it said 'default plug n play monitor' and didn't show the gfx card or anything
(!! ANSWER FOLLOWING QUESTION IN A REPLY) Think if I reinstall Windows 2k3 Server it may fix?
I'm really not wanting to swap motherboards or processors.. .(!! ANSWER FOLLOWING QUESTION IN A REPLY) and anyhow if it was the processor at fault, it would do it a lot more often right? I mean the processor is always processing data idle or not... so, it should crash with more of a pattern then randomly right?
I've already fried my computer trying to troubleshoot this son of a *****.... I put it's ram (troubleshooting to see if this comps ram is bad) in my system, it went in backwards (was dark conditions, it's keyed yes, but obviously not keyed enough to prevent pin contact) and blew my motherboard up
I'm really getting tired of this, (!! ANSWER FOLLOWING QUESTION IN A REPLY) would a PC repair shop be able to troubleshoot this efficiently or would they likley say it's repaired me fork over 100 bucks and then it **** up again?
I'm getting really stressed over this problem as I pay my hard earned cash and then I have to keep investing and investing in new parts to put in it to see if it works right. I don't want to buy a new processor to find out if my processor is the problem etc...
This is really terrible.... I hope someone has expierience in troubleshooting problems that only crop up every 3 hours or so (which make it hard as HELL to troubleshoot)
Is there any special equipment I could buy to locate this problem rather than buy a new component every damn day to replace... Thanks
This may not fit in this forums catagory, but then again I don't see a hardware troubleshooting section though I didn't look hard'
My setup is
WD HD
