I'm not TC, of course, but I can offer a few suggestions.
I have one box that is an Epox 8K7A with an AMD MP
[email protected] and it turns .4xx AR's in 3.25hrs.
Hardware wise, OC your rig to the highest stable fsb setting that you can. In the case of my
[email protected] it is at 164x9 (default multiplier). Also set your memory timings as agressively as possible - on my Epox using Corsair PC2400 DDR, they are at 8/8/8/2/2/2/2. Make sure that all power saving settings in BIOS are turned off.
System config wise:
Run the CLC version of the
[email protected] prog.
Turn off all power saving settings, except monitor (if you like your monitor to power down - I personally just physically turn it off.)
If you run Microsoft office, disable Find Fast, located in the Control Panel.
If you have AntiVirus software, exclude the folder that seti resides in.
Optimize your swap file on the hard disk - this can be accomplished with Norton Speed Disk or Nuts and Bolts. Have the swap file moved to the front of the disk.
Run minimal background tasks. Turn off all unnecessary apps.
If you have a graphics program, such as Corel, make sure all file indexers are disabled.
Hopefully these items will help - and I am sure that TC will have more to add to this list - especially the hardware part, as I only run AMD rigs.
Happy Crunching.
