- Oct 14, 2007
Hi BF3 fans! AMD sent me a key for the game to test out a couple of their video cards. So far I've tested the 6970 & 6990 individually and will be testing them in tri-fire as time allows (probably early next week). If you don't already have them, both companies have drivers for BF3 out (AMD is supposed to be finalizing theirs relatively soon).
So far, EarthDog has tested a GTX580 for me and MattNo5ss plans on testing two in SLI. I'd like to get some more GPU data if possible, but the system requirements are pretty specific. If you don't have identical RAM, I think that can be excused and I'll just put a * next to your result noting that in the article. The most important is that you match the CPU & its overclock. Here are the specs:
The method of testing is manual, but is remarkably consistent (we're talking less than 1 FPS difference between runs). Instructions:
The nature of this level makes it perfect for consistent and repeatable FPS results, which is why we decided to go with it. Plus it doesn't require people to play far into the game. There is a lot of detail to stress the GPU. Of course, being enclosed, this level will give slightly higher FPS than a massive 64 player online map. I'll play Caspian Border and record some FPS runs to see how much it drops, then make a note in the article.
If you have the system and want to take approx 20min to help out with the article, we'd be grateful! I'm hoping to publish it sometime next week; anyone that tests will be mentioned in the article of course. For results, please post your GPU info (and RAM if applicable), then upload the minmaxavg excel spreadsheets from your runs; zipped might be easiest so you only have to upload once. If you feel nice and want to make life easier you can rename the files like GPU-r1-stock-minmaxavg.xls or GPU-oc-coremhz_memmhz-minmaxavg.xls. For example:
Let me know if you have any questions or if anything above is unclear. Thanks to anyone that's able to help out!![Salute :salute: :salute:](/forums/images/smilies/salute.gif)
List of GPUs Already Tested (so we don't have duplicates)
Single 6970 - Stock & Overclocked to 960 core, memory stock.
Single 6990 - Stock & Overclocked to 960 cores, memory stock
Single GTX580 - Stock & Overclocked to 922/1844/2103
Tri-fire 6990 + 6970 - Stock & Overclocked to 950 cores, memory stock
- AMD users should be on the 11.10 version 3 preview driver.
- Nvidia users should be on the 285.62 WHQL driver.
- i7 2600K @ 4.5 GHz (Removing any possible CPU bottleneck.)
- DDR3-2133 / 9-11-9-28 (If you don't have that, but have the CPU run at the required overclock, just note your RAM speed & timings in your post)
- {BYO GPU} running @ stock
- The game test should be run at 1920 x 1080 and using the "Ultra" setting, with all the defaults that applies when set.
- Turn on Fraps
- Start the first mission: Operation Semper Fidelis
- Begin recording FPS (F11 by default) after you pick up the pistol and are looking forward.
- Work through the level as normal.
- Stop recording FPS when you're at the end of the level and the game takes over motion, hit F11 again when the guy puts his hands up.
- Repeat 3x at stock (the runs take approx 5 min each including the beginning cutscene).
- (Optional) If you feel ambitious, overclock your GPU to its stable 24/7 overclock and run it once.
- HD6970-r1-stock-minmaxavg.xls
- HD6970-oc-960mhz_1275mhz-minmaxavg.xls
