Sounds like you and others here have determined the 4.3ghz is a realistic oc limit imposed by diminishing gains and perhaps an optimal, safe core voltage. My question is, would you still see higher Cinebench scores with the processor at say, 4.4, 4.6 or 4.7 Ghz? Perhaps at the expense of excessive heat and/or an unhealthy vcore? >=> Some increase as you continue upward in Mhz but not nearly the amount of increase as seen when moving up to 4.3Ghz. That is what makes it not really worth the real extra heat that caused many of us that do overclock 24/7 to have to resort to + $250 dollar water cooling to ward off the heat.
Have you been able to run Pi calculations with the 8120 ... or see how it trends above 4.3 with any other benchmarks? >=> No matter what benches anyone runs and posts; there always those wanting another. No I have not run others than some real work I did with the FX-8120 and now the FX-8120 is no longer mine. Got the 10 to 15% more powerful FX-8350 in its place.
and why is there such a dip and then jump in performance at ~5.3ghz on the 8350 chart? sorry if some of these have already been answered, I read the entire thread but couldn't find much other than a response on page 2 from ssjwizard. >=> There was an odd jump on both the FX-8120 (no longer have) and the FX-8350. A little less of an odd jump on the FX-8350 if I remember right. Have not looked at the graphs in quite some time.
I honestly have not debated that jump with anyone. It takes some really good water; even cold water, to run up there in the plus 5.0Ghz speed for any length of time. When a user hits his board with DICE or LN2 or Helium, they are not playing around at the just above 5.0Ghz speeds but are running for BIG numbers, so the oddness has not come up anywhere at all that I was able to find.
So given that it would take at least single stage phase cooling to try and run above 5.0Ghz all day everyday...I just have not pursued the oddity beyond 5.0Ghz. I use 4.0Ghz day in and day out and do all my Video Editting at 4.8Ghz which I can do easily with my water setup.
RGone...
