- Feb 18, 2002
Try removing the heatspreders, and either leave them bare with air blowing accross them or fasion your own heat spreaders.
If you open them up you'll see they use a strip of some kind of heat transfering fiber. they dont actually even make direct contact with the alluminum spreader.
MrNatural said:I think what may be happening is the RDRAM reaches a certain temp it throttles back like the P4 does, The reason I say that is because I found that if I remove the fan I have blowing accross the RIMMS then they don't reach the higher speeds even with the higher vrimm woltage but as soon as I place the fan back then they go higher.
