- Mar 16, 2003
mysterfix said:I am going to try it on an old video card that I know works.
So I'm curios, did you ever try it on that old vid card? and does it still work?
Yes they do. STUCK.kayson said:Someone needs to make a sticky that says "DON'T USE COLD HEAT FOR ELECTRONICS"...
mysterfix said:Hey guys, I just picked up one of these bad boys and I must say it works great! It actually works just as advertised. You simply touch the end to what ever your going to solder and the thing instantly heats up and melts the solder.
[/URL][/IMG]
This is a practice run that I did to see how hard it is to use. Very easy indeed.
[/URL][/IMG]
TUK101 said:I bought one thinking that it would work ok for welding broken wires on my wood truck or tractor when they are too far away from the house to stretch a cord to etc. Anyways, I tried welding two wires together that had just been taped and twisted together on my old tractor and well..... that cold heat soldering iron wouldnt do it. I have tried it on many different things (not electronics) and it barely melts the solder. I dont know what they did on TV to make it work, (probably had the pieces red hot seconds before filming), but I cannot even get a descent cold weld with it. Stick to the gas or electric soldering irons, the Cold Heat welder is a joke.
Moto7451 said:This reminds me of a lecture we had in physics. Signs on high-wires that say "Danger High Voltage" are really an oxymoron of sorts because its the current that kills. Static electricity has a huge voltage but so little current that at best its going to surprise you and maybe hurt a tiny bit. Thats also why you can get away with touching things like Van De Graph generators (the things that make your hair go crazy when you touch them ).
ozzlo said:...then I started wondering why in the world the iorn needed to jump up to 800 degrees when solder melts way less themperature than that..
... I will stick to my elcheapo tequnique by pre tinning the wires using $6 iorn...
