GotNoRice said:Can you unlock AthlonXP's (For MP use) with a pencil like TBirds?
No, you need to bridge the L5 bridge with some conductive fluid.
Attempts to use pencils have been unsuccessful.
Jon said:Initial reports indicate that Bartons are compatible with the MPX chipset and are also SMP capable. (It has now been verified that Bartons will run on the Iwill MPX2 and the MSI K7D Master.) Please note that Bartons are manufacted to run at 166 FSB, so you will probably want to modify the multiplier on them, if you run them on a dual system with FSB below 166. The bridge codes for Bartons are identical to T-breds and those manufactured with a stock multiplier below 12.5 should be unlocked, though only on motherboards that allow multiplier change, such as the MSI K7D Master
