- Jul 16, 2005
- Bermuda
Fumes could also be flux that was not properly cleaned off of the card....flux stinks....but so does burning plastic....
Damn, I just ended up with a BFG Geforce 6800GS OC that will randomly blackscreen/glitch screen and i was thinking of baking it, but it can't find an rohs logo on it. I'm not sure i want to take the chance of ruining my gf's oven or realsing poisonous fumes in our place.
Maybe I can bake the P5K Deluxe motherboard I have here that is acting up!
i had to post here... IT WORKED FOR ME TOO!
today i was bored, reading some old threads and found this one regarding baking a 8800gtx thinking, "wtf? they can't be serious". then read through a few pages and it looked legit. watched a couple of videos on Youtube and was sold - pulled my broken 8800gtx out of the drawer and gave it a try - fugger worked like a charm. lucky for me i had a full tube of Artic Silver Ceramic sitting around.
so, now i have a 275 and an 8800gtx for my second box that i was contemplating giving to pops for when my neices and nephews visit. should i use the 8800gtx for physics with the 275 as the main?
not looking to build another box as i just spent $3k+ on a sandy bridge machine last month
To the original poster - THANK YOU. baking a broken $500 video card was probably the coolest thing i have ever done with a pc component.
i hope you didnt use a full tube of as5 on it... thats overly much.
either way, as far as aphyx card, check the phyx game list... id be willing to bet you have VERY few if any games that support phyx... and thus it wont be worth it to have the extra card drawing power constantly.
wow. over 160k views here and almost 600k on hardforum, totalling almost 1500 replies. props to the OP for this ingenious idea!
Admittedly I was skeptical of this method when I first read about it, okay actually I thought it was ludicrous, because I figured if anything putting a piece of computer hardware (or anything electronic for that matter) into a hot oven would reduce said hardware to a smoking pile of silicon, ram chips, transistors, capacitors, and other assorted components and might very well result in it bursting into flames.
To my amazement though, this trick actually worked for me on an old 8800GTX I bought as a non-functional unit from another member here.
I could not even get my computer to boot with this card in the first time I tried it, but right now it is running just fine with that very same card in it without issue (post-baking of course).
I decided to just do a short bake on mine, since I was wary of the idea, and only put the card in for five minutes.
I guess that makes another success story and recommendation for this procedure.
Wah, wah, wah.
Card died again.
Put it in last night and couldn't get the system to post, then on the second try it posted but was artifacting pretty bad with parallel lines running down the screen, it hung up after post and refused to boot.
So, the oven is heating up right now and hopefully a re-bake will do it.
I just don't think I had it in long enough the first time, because initially after the first baking I had those same lines on boot up, but it went away then.
