- Apr 1, 2004
- Vancouver Canada
A water chiller isn't as effective as a direct die unit. There are a lot of losses in all the different themal contacts. The chiller systems you usually see are so big because people typically make them out of air conditioning units. These units are pretty big, and their evaorators are quite large as well. Once you put the evaporatr in a tank big enough for it and a pump, you end up with a very large setup.
-50c isn't very typical for a waterchiller. I would say most units will give cpu temperatures in the -15 to -25 range, although some are better. A direct die sytem with the same compressor and consensor as a waterchiller will probably be at least 10 degrees colder on the cpu. (best guess, not really sure)
