You would be better off using thermal adhesive. It cost more, around 15 bucks but it will work better. 2CoolTek sells both, but I highly recommend that you go with Artic Silver thermal adhesive.
i think pcnut has it for 8 or 9 bucks you can also use regular epoxy and radioshack thermal paste it would be better than frag tape. all you do is get some 5 minute epoxy and put a little on each corner of the chip and then smear some thermal paste in the middle and put your sink on and then put a little weight on it for about 30 minutes or so. its much cheaper and works very well
