- Jan 13, 2005
ok since no one in my back water town stocks any sort of raw copper plate i have to resort to buying online.
But since i am not able to see this in person i was wondering what you guys would recommend in terms of thickness for the copper plate.
i'm looking for something i can bend with a "metal brake" (see bench vice with some old bed frame chunks)
i have some aluminum heatsinks from old dell tower chipsets that are the perfect size if i chop them in half.
my plan is, bend some copper to make a base plate, solder the chipset heatsinks to the copper plate, drill/tap (or carrage screw and nut) holes in the plate to mount it to the board.
Apply to card with thermal pads.
I want to be able to go back to stock if i want to, only thing i would be spending on would be the copper plate and thermal pads In case if any one is wondering...
i just want something that can apply good pressure to the thermal pads when i get it mounted under the kraken g12
