OK, looked into w/c and dont think its rly worth it in the long run, might as well go straight to mach2 or prommy. My 754 3200+ is at 2.6 (10x260) 1.6vCore 24 hour prime stable. BUT i cant seem to get to 270 using the vCore im happy with (1.75 on air).
I know that running a cpu sub 0 can give better o/c without using high voltages, but is it rly worth it? will i be able to use a mach2 on cpus in the nxt 2 years? will be break 2.7-2.8?
Any help would be appreciated
Thanks
Thanks
