CorvusDove
- Jul 18, 2017
I saw the Thermaltake WP200 go on sale on Amazon for effectively the price of just the W200 on a flash sale. I'd been drooling after a case with so much room in which to work, so I snagged it. It was, of course, after I assembled the base frame of this case that I discovered I don't have nearly enough cooling fans to fill this case out. I'm moving the following from an Antec Twelve-Hundred:
i7 2600k @ 4.76ghz (Air) Noctua D15 Cooler on ASrock Extreme4
16GB Kingston HyperX DDR3
EVGA GTX 1070 FTW @ FTW-Stock
1x Intel Sata III SSD (OS, Core Apps) 120GB
1x Generic SATA III 500GB SSD
1x 3TB Seagate 7200RPM HDD
1x 1TB Corsair SSD (in hotswap bay)
1x 2TB Western Digital 7200RPM HDD
1.2KW Antec PSU
1x Internal HDD/SDD hot swap bay
1x LG BD-RW
1x 5.25" Bay USB HUB (2/3)
1x Soundblaster X-Fi (Internal)
I also plan to add a second computer to the other side of the case that won't be nearly so powerful, but heat will obviously be an issue. Drives for both machines will be on the 5.25" bays on the left side of the case. Power supplies will be stowed in the P200 section of the case with cables raised up through the ports at the bottom of the W200 section. This leaves up to 16 fans to obtain for the P200 section (6 bottom, 8 sides, 2 fore) and 22 in the W200 section (8 top, 8 one side, 4 fore, 2 rear). I can also add 4-6 fans to the bottom of the W200 section but I don't see that actually doing anything other than inhibiting airflow from the P200 section.
No matter what, I'm about to spend a lot of money on fans, but I'm not sure which approach is best, or even necessary. Every fan mount can hold a 120mm or 140mm fan, and the ones on the side can also be 3x 200mm instead of 4x 120/140mm. The top can hold either up to 8x 120/140mm or a single row of 3x 200mm fans straddling the middle of the case. I'm overwhelmed, especially since this will be expensive; what size fans should I use for each fan array to get the best cooling/cost? 30+ fans is hard to sort out! I've been looking at Solar Eclipse fans in the 120mm range.
1.2KW Antec PSU
1x LG BD-RW
