I'm posting some tips I've found that work for me in boosting the performace of my 6800GT. I haven't seen to many scores higher especially at my CPU level.
1st BIOS mod. Use nvflash to backup your current BIOS and use Omniextremeedit to up the voltage from 1.3v to 1.4v. This will come in handy as you crank up the GPU speed.
2nd up your apeture size to 128 or 256. You may or may not find this helps you. In my case the benchmark score did not change but game play apeared to be smoother.
3rd newer drivers. I'm running 65.73 Nividia drivers which seem to help everything related to this card. Frame rates increased approx 2-3 fps. Benchmark score also improved as well. Nvidia is working hard it seems to refine the drivers for the 6800's.
4th speed. I OC'd my GPU in 3d to 420Mhz. The ram I have set a 1.10 any higher doesn't seem to result in any better scores and only pushing the hardware more then needed. I can run at 1.20 with no artifacts but game play nor benchmark scores change. The GPU may even go higher without issue but thats as high as I can go with the current BIOS.
5th Up the 2d GPU speed to 380Mhz. No increase in overall temps and the benchmark score went up slightly. Why I don't know but they did.
The above changes got me a consistant 12,766 in 3dmark03.
Items i've yet to try but want to.
Golden Sample BIOS (should allow GPU to go to 450Mhz) I think the GPU will do it with adequete cooling.
Better power supply (i'm getting some voltage variations, even audiable changes under load) new one on the way.
If anyone else has tweaks or changes that have worked for them post away as it will only help.
Jeff
Jeff
