Haha, trying to make sure I was getting a vmem reading right my hand slipped. I had the multimeter ground on the screw holding the radeon 8500LE in place, and I don't know what the positive lead ended up hitting (it was some part on the radeon). Suddenly there was a white flash (not sure if it was on the card, or my peripheral vision showing the monitor). The monitor went white, and subsequent booting shows totally corrupted flashy textures and such.
The card is basically dead. Maybe a bios flash would help it I don't know and frankly don't care because luckily I'm in my 30 day return period! Plus I paid 30 bucks extra for a 3 year no questions asked over the counter exchange warranty at Future Shop. THANK GOD FOR THAT.
What I'm wondering is is it possible to mess up your motherboard AND CPU and mem and stuff by shorting something on the AGP card itself? Or is it just going to blow out the card. Reason I ask is because I have no backup card to test my system.
It boots fine but seems not to go into windows right away like normal... there is a 30 second delay or so which is weird. Maybe somehow the CMOS got cleared and it's searching for a cdrom or something. It's scaring me. Booting from a floppy makes the normal sounds though, so I have hope that things are ok minus the card.
Gonna get a replacement but was wondering if it was feasible to worry that I fried my motherboard/cpu/memory? I doubt it but it's a bit scary. The rest of the parts are not warranted because I bought them from computer stores.
This has taught me one thing: when taking readings with the power on, make sure you have the best angle of entry into the case, because if you slip even a bit, you can cause some nasty stuff.
