Gigabyte UD3P
AMD FX 8370 @ 4.5
16G RAM:
8G Kingston Hyper X rated @ 1600/1.65V
8G Kingston HyperX Fury rated @ 1600/1.5V
According to instructions, I installed the same type of memory in the 2 opposing slots.
However, the mobo only allows me to control the voltages on Channel A (slot 1&2), and Channel B (slot 3&4). I can't control the individual voltage for each slot.
So, the 2 older sticks of RAM are running @ 1.5V when they should be running @ 1.65.
Is this ok? Or can the newer 1.5 sticks be overvolted to 1.65?
Or should I set them all somewhere in-between?
Thanks!
AMD FX 8370 @ 4.5
16G RAM:
Thanks!
