I found this old laptop at work that's been sitting around gathering dust for 4+ years. Decided to take it home, check it out and found out it still works! I'm thinking of using this as a basic web browsing, online chatting, alternative to whenever my PC is out of commission because of part swapping or stress testing, etc. Obviously, that sort of thing doesn't require much which is great as this laptop isn't the snappiest thing on the block. I identified it as a Toshiba Satellite 2405-S201 and found the specs here:
http://www.csd.toshiba.com/cgi-bin/...BV_EngineID=cccdadeehdfkedlcgfkceghdgngdgnj.0
I've never messed with laptops before and I'm wondering what I can do to make the most of it. The first thing I thought of is to get this thing WiFi enabled with a cheap USB adaptor. Next idea was to swap out the 256 stick in there with one 512 (512 max mem sucks ). Then I wondered about maybe replacing the hard drive.
Any thoughts or ideas? The WiFi adaptor is the only thing I'm dead set on, I just have no idea if the memory or HD upgrade, or any other upgrades you guys can think of, would be worth it.
