I had some questions about conflicting information I had seen around about base finish on heatsinks and waterblocks. I know that theory states that the smoother an interface is, the lower thermal resistance it will have.
I had heard some possible concerns with ultra smooth finishes causing degraded performance over time due to the thermal grease actually 'pumping out.' Although I've never seen this effect personally, I figured it was worth my time to ask the 'pros,' so I sent an email off to Arctic Silver's tech suport. Here's what they had to say.
Keep in mind that this may not be true with all thermal compounds, but since I use ASIII, I asked them.
One very important thing to note, a smooth base may not be the most flat base. So, if you are lapping, make sure you're doing it on a flat surface. I use a toolroom grade B granite surface plate. It's guaranteed flat to within 0.0001".
Just thought this info might be useful to y'all. Enjoy!
email quoted with permission.
Bryan,
There is no such thing as a surface that is to smooth. The finer
the finish, the less thermal grease will be needed. With a highly
polished and flat surface, a proper application of thermal grease will appear to be missing when the waterblock is removed from the CPU.
One caution on lapping, it's hard for an end user to keep the surface flat. Lapping a water block with a super flat base like a Swiftech would be counterproductive.
Colin Thompson
Arctic Silver, Inc.
Phone: (559)740-0912
Fax: (559)740-0913
--- Original Message ---
Hi,
I am wanting to lap my waterblock for optimum performance for the next 6 months. I have heard conflicting information regarding the optimum sandpaper grit to stop at. I have seen some people
who stop after 400 grit... others go to 2000 grit, a near mirror finish.
The conflicting information I've heard is that if you lap too much, and have too smooth of a surface, you may get a 'pump out' effect of the thermal paste. I would like to get the opinion of
a manufacturer, as I would trust your opinion.
Assuming the base if flat, what is the optimum roughness (rz, ra, or sandpaper grit) for arctic silver 3 and arctic silver 5?
Thanks for your time,
Bryan
