Exactly. And, I wouldn't recommend using either the 1800 nor the 2300 just because they're "rated" at a higher flow. Sure, if we're running ponds, I would, but we're running water cooling systems in restrictive loops which run at nearly the maximum pressure these pumps are rated for.
Via Aqua 1300 - 6ft of head, 31.5 watts
Via Aqua 1800 - 6ft of Head, ??? watts
Via Aqua 2300 - 7ft of head, 41 watts
Anything larger than the 1300 would just create more heat dump and stress out the pump. Just because they're bigger and rated for higher flow doesn't mean they're better.
