You're correct, the pump water speed and head height are very important factors in cooling. The radiator only can transfer as much heat as the pump can send to it. However don't go over~40 watts to get this speed, or you're wasting money/time/effort.
There were a lot of people running the 1300 in-line instead of submerged (when I bought mine, it was set up to run inline with 1/2" barbs already fitted).
The manual is translated Chinese to English, but it's pretty clear they say to run it submerged only...twice.
Heat makes epoxy bedded copper coils do funny things, and leaks just don't matter underwater.
And you simply cannot blame the pump for all the hamfisted and odd things we put it through.
Honestly if it were built idiot-proof, it would cost 8 times as much, plus someone is always hard at work building a better idiot.
Mine has always ran great. Two years of faithful service and it was retired simply because I bought this much bigger 1" pump I use now.
I actually still have all my pumps, and they all work just fine. Danner mag2, VA 1300, Maxi Jet, and currently a Quiet One 3000.
Take care of your toys and they will take care of you.
