Via Aqua Pump
Istari1
Raleigh NC
Anyone used/heardof/seen/heard one this these pumps? AquaStealth is seeling a model with 1/2" barbs already installed and a GPH of 370!!! For only $23. I have never heard of this pump, but at 370 GPH thats an insanely low price. I just finished modding the heater core I bought from Auto Zone with some 1/2 barbs, now all I need is to decide on a WB and a pump and I'll be all set.
Josh
Maximus Nickus
Senior Shaman
Milton Keynes, U.K.
Go to www.leufkentechnologies.com (Aqua's sister website) and look at there pumps.
For $60 I got a 400GPH pump and Alu Resevoir. The pump is externally mounted for cooler temps too.
In my experience there great pumps, with superb noise free operation.
But get the 3/8 fittings one, the only reason for 1/2 is higher flowrate, with 3/8 you get better cooling due to the increased amount of H20, and with a pump over 300GPH your flowrate is superb too.
Happy Cooling!
M_N
Istari1
Istari1
Raleigh NC
ocean said:
Or go here and puchase juyst the pump for about 25 bucks:D
Hmm..but my first posts said I could buy the pump with modified fittings for $23, so why would I buy the stock one for $25? :)
Josh
