- Apr 2, 2012
- London - England
I've overclocked my 2500k to 4.5GHz however I've found that it needs a lot of juice to run stable.... My settings below.
Multiplier: 45x
Base clock: 100
Ram voltage: 1.65V (as on label)
Ram timings: 9,9,9,24,2 (Corsair XMS3 8GB 1600MHz / 2x4GB Kit)
Voltage Offset: +0.005V
LLC: Enabled (Asus P8Z68-M Pro motherboard, can't set levels, enabled/disabled/auto only)
Spread spectrum: Disabled
PLL Overvoltage: Disabled (Running at 1.8V Stock, can't go lower, 1.8V or 1.9V options only)
vtt: Stock 1.050V
C3 and C6 disabled
C1E and speedstep: enabled
Now, after running IBT, I get peak voltages of 1.40V, im guessing this is when LLC kicks in, voltage never goes higher than this, on prime 95, the voltage is between 1.37-1.38V whilst running blend. At these voltages I pass IBT on max ram settings, 10 loops (have not tried more). And prime 95 runs perfect for 12+ hours, maximum prime time for 15 hours and it was stable.
If I reduce the voltages I end up getting BSOD error 124 or rounding errors in prime95, with the 124 error I tried upping the vccio gradually rather than the offset however then I end up getting BSOD 101, so its definitely too low a vcore. And I can't reduce pll voltage, minimum is 1.8V.
Just wanted to hear your opinions on these settings, acceptable? Anyone else running these voltages at this clock speed.
Btw. My 4.2GHz clock is at 1.28V, bsod 101 any lower.
Anything past 4.2GHz, and I really have to up the vcore.
Temps are also within limits, using a noctua nh-d14 cooler.
Highest is 78C with IBT, and around 68 with prime.
Normal pc use, encoding videos, etc, around 62C max.
Multiplier: 45x
Base clock: 100
vtt: Stock 1.050V
C3 and C6 disabled
