Ok, so I originally sold off my x2 3800+ and dfi mobo after months of instability and headaches, in favour of my new 920d system. The cpu was purchased around xmas time if I remember, and is from the exact same batch as our very own Sentential's 920 chip. However, due to a distinct lack of funs the project has sat on hold until this month, when after buying one part at a time as money came in, I finally had all I need for a complete pc
So what do we have now? Well my 920 at the ready, iv backed it up with a 700w FSP psu, 2gb pqi pc5400, 256mb 7800gtx and an Asus p5wdg2-ws mobo... why? as here in the uk the WS was only £20 more expensive than the p5wd2-e, and the ws 8 phase power was supposed to be much better, so i figured id pay a little extra and get a bit more.... Wrong!!
That said, let the overclocking begin!
Cooling is a Storm g4 block, maze4 gpu, d5 pump and a thermochill pa120.2 rad with 2x silent fans..... idle temps at stock speed/volts was 28*c CPU and 27*c GPU
However stock load temps were more like 40*c CPU and 33*c GPU...
So...the mobo...where shall I start? the 8 phase power maybe? it seems to be a joke - the vcore on this mobo is rediculous...its all over the freakin place, and its a constant battle to get just the right setting to not overvolt at idle, but not drop to low at load! At stock speeds and stock 1.3v set in the bios I was reading 1.38v idle in windows, and a perfect 1.3 / 1.31v load (thats via software AND a multi meter...the software is pretty accurate at voltage reading!). Stock temps were MUCH better after i reduced the bios vcore to 1.275v...giving 1.272v load and 1.33v idle...
Also, the mobo wont restart (a common WS problem) - if you tell windows to restart it shuts down and turns off. If you go into the bios and hit 'save changes and reboot' it simply turns off - it saves the changes, but it doesnt restart. Noone knows why...Asus can probably fix it if they could be bothered.
Oh, the WS advertises the fact it has 8 sata ports, and that you can raid 4 of them - WRONG, you actually cant - there are NO raid drivers for the chip theyre using yet that I can find, and according to asus support they have no idea if there ever will actually be any. Also, the dual onboard lan can only be enabled using a new beta driver, which atm is causing me a ton of grief.
Bios updates also seem to be non existent, and oh boy does this board need some.
But enough of the moaning about the board...other than these problems at least it seems to be a stable board (compared to my 4 dead dfi mobos) once youve figured the oddities out.
Sooooo, time to OC the cpu I read a ton of guides, and threads on XS about the mobo - i figure out the bios settings I do and dont want, and thanks to an asus support forum thread written by a member of the public (as Asus support is RUBBISH) I find what the best stock settings are, and where to start overclocking. I also get a mate over who knows a thing or to about intel OC'ing to give me a hand as this is my first 775 setup.
Encouraged by everyone elses decent overclocks on air, let alone water we go for a modest 3.5ghz - 1.275v in bios, 250fsb 1:1 with ram (@1.8v 4-4-4-12)... its dual prime stable for as long as you like, 1.34v idle with vcore dropping to 1.264 load. Then try for 4ghz - i just couldnt help myself 290fsb and 1.4v set in bios (1.46v idle, 1.36v load)... run prime and one core fails imediately...the other will run for as long as you want. Same goes for 4.2 and 4.4ghz - one core will prime for hours...the 2nd fails straight away...even with higher volts the 2nd core wont seem to stablise. I can only theorise that 1.45v load might make it stable...but thatl be giving it 1.55v + idle...something I wont do given current temps and streak of bad luck.
I dont have the skills to vmod this board to stop this stupid droop, so Iv just got to make the most... ATM im running at 3.8ghz (270ish fsb) and 1.3v in bios (1.35v idle, 1.26v load) and both cores are dual fully prime95 stable... temps are 30*c idle and 45-47*c load gtx loads at 33/34*c in the same loop...
do those temps seem right? the fans on the rad are at full 12v and really quiet...supposedly 45ish cfm...they certainly push plenty of air thru the rad.
Benchmark wise this chip is embaressing, pulling in much lower superpi / sisoft sandra / 3dmrk (all versions) / pcmrk / aquamark scores than my old x2 at 2.8ghz... even tho my gpu is now clocked much higher than it used to be. Hell, this chip at 3.8ghz has yet to beat anything my old x2 ever scored...
I can get a conroe ES chip if I want, but my mobo doesnt support it and my source for the cpu couldnt get me a compatible mobo very easily...plus this setup and endless bad luck has broken the bank completely.
So what do you folks suggest? any hints/tips/pointers or general advice? or just any comments youd like to make?
cheers!
cheers!
