Hehe
Well I do realize all this is easier talked about than done, and sounds like a pipe dream. This exercise is not only planning, but also feasibility study - at some point I may have to scale back or call it altogether. But I am fairly serious about this idea - I'm not just BSing and wasting your time. I do want to make it happen.
Conumdrum, point about two loops well taken. I'm pushing hard to minimize the number of boxes - if possible, I'd rather have one huge rad than two smaller ones. But you might be right, especially with 7 graphics cards the CPU might get fried.
How about I get 2 massive rads (say 2 NOVAs), and make one loop for 5 GPUs, other loop for 2 GPUs and CPU? This second loop should be fairly piece of cake for such a rad?
As to the CPU block, thanks for the tips - I didn't research that at all, just picked something at the same website to have a sense of total cost. Will look into what is real good before actually buying.
Finally, you say "look at this chart" but I don't see anything - there might be a broken link or something.
Daddyjaxx, 2 things. First, I don't expect to use up all that tubing - added some extra, in case I mess up, or cut too short and need to replace, or whatever. Secondly, someone else in this thread (Spawn I believe) said that tubing length doesn't matter too much. If it does - can I just get more powerful pumps, or this is something completely impossible?
My closet window is about 20-25ft apart from the spot where I was thinking to place the case. However, if this is a major complication, I might put the case itself into the closet as well (distance will reduce to like 5ft) and use cable extenders for monitor/keyboard/mouse.
As to "upped to 7" - I'm toying with this idea, but I can't really understand whether this will actually work. 2 things that bother me are the physical density of installation (will I be able to stuff all that in and connect the tubing etc?) and motherboard/OS limits (will it end up choking on 14 GPUs?)
