- Jul 15, 2005
I currently have a Gf5500 FX 256mb AGP 8x card, and I want to upgrade. I have done quite a bit of research and a lot of comparisons, and I have narrowed my choices to 3 cards by PNY. I chose PNY because they seem to be very up front with their card specs, where some other makers were not. Plus, I have have used PNY in the past, so I am familiar with their products. I might have had an ASUS on my list, but they didn't tell me everything I wanted to know.
My choices are these:
PNY Verto GeForce 6600GT 128MB AGP 8X ($174.95 at ZipZoomFly)
SPECS: NVIDIA® CineFX™ 3.0 Engine
Superscalar GPU architecture
500MHz core clock
128-bit high-speed DDR3 memory interface
900MHz memory data rate
14.4GB/sec. memory bandwidth
4.0 billion texels/sec. fill rate
375 million vertices/sec. setup
8 pixels per clock (peak)
16 textures per pixel (max in single pass)
Dual 400MHz RAMDAC's
Maximum display resolution 2048 x 1536 @ 85Hz
Flat-panel display support with resolutions up to 1920 x 1200
##Requires a 300W Power Supply##
PNY Verto GeForce 6800 AGP 8X 128MB DDR ($199.00 at ZZF)
SPECS: VGA + DVI + S-Video Outputs
NVIDIA® CineFX 3.0 engine
Superscaler GPU architecture with 12 rendering pipelines
325MHz core clock
256-bit DDR memory interface
700MHz memory data rate
22.4GB/sec. memory bandwidth
3.9 billion texels/sec. fill rate
406 million vertices/sec. setup
12 pixels per clock (peak)
16 textures per pixel(max in a single rendering pass)
Dual 400MHz RAMDACs
Maximum display resolution 2048 x 1536 at 85Hz
Flat panel display support with resolutions up to 1600 x 1200
PNY Verto GeForce 6800GT AGP 8X 256MB DDR3 ($415.00 at ZZF)
Specs: NVIDIA® CineFX 3.0 engine
Superscaler GPU architecture with 16 rendering pipelines
350MHz core clock
256-bit high-speed DDR3 memory interface
1GHz memory data rate
32GB/sec. memory bandwidth
5.6 billion texels/sec. fill rate
525 million vertices/sec. setup
16 pixels per clock (peak)
Dual 400MHz RAMDACs
Should I go with the 6600GT and its 500/900 clock speeds, the 6800 (slower clocks and data rate, but 12 pipes) or spend more $$ on the 6800GT? (slower clocks, but 16 pipes, more memory and data rate/bandwidth for days)
I will ultimately choose one of them, but I was hoping some other opinions or advice will help me.
500MHz core clock
325MHz core clock
Dual 400MHz RAMDACs
350MHz core clock
Dual 400MHz RAMDACs
