- Jan 15, 2001
- Denver, CO
I've setup a fairly simple procedure for installing the Seti CLC as a windows service in NT 2K XP Net. You can not only name the service whatever you like, but you can also rename the seti client so it shows up in the process list by whatever name you wish. This is handy for those home systems where several different users login and either refuse or simply forget to keep Seti running for you. It also completely hides it so they have no idea what it is if they look in the process list. My instruction list is currently beta, so if you have any trouble let me know. The files are fine, but I may have left a step out, or something might not be worded the best. If you give it a try let me know how it goes. I hope this helps some people. It gives you a lot of control over setting it up, and once you edit the files you simply run the batch file and it's done. As always, only run Seti on machines which you have permission to use. Don't ask other people to run Seti for you on machines which you do not have permission to use. Here are the necessary files zipped up in rar format. You can get win rar from www.rarlabs.com
http://www.ocsetiteam.com/files/seti_service.rar
