- Mar 31, 2005
- Stealing your megahurtz at night
So I was streaming a Hi-Def movie (MKV) to my PS3 with Playstation Media Server, and my wife decided that she wanted to download the trial version of Photoshop CS5. I noticed that while she was downloading, that my movie started to show signs that the network was getting a bit too busy to keep up with the video. I have a WRT54G V2.2, with stock firmware. I am starting to think, instead of spending the money on a new router, that I should give DD-WRT a try, since I have heard that it can handle more simultaneous connections than the stock firmware. So the first thing I do is start poking around for directions, and I start getting a little confused. I have someone telling me that I don't need to flash the mini version before flashing the full size, but the website is saying that I should. Also, when I check the router database, I get a message that says that this version works best with the VINT builds. So I start looking through the list of firmware that the site brings up when I put in the model and version number, and I get all of these different things, like VINTAGE : voip and things like that. I am really confused, because there was another page that I had seen looking around a bit, saying that the router is perfectly stable on the newest and Vintage builds.
As I am looking through the list of compatible firmware, I can't find a single one that says anything about being the normal build, only the VINT. Am I looking in the wrong place, or will I really be better off using the Vintage build? I am also a little confused about whether or not I really need to flash the mini version before I go any farther. I have read some posts around the net where it seems that people just flashed the full version and were fine, and I have read in the instructions, HERE, that I need to flash the mini first.![bang head :bang head :bang head](/forums/oc_images/images/smilies/banghead.gif)
I may just end up changing all of my network to wireless N. I haven't really decided for sure on that, if I can still get some life out of this router I have now. Any suggestions?
DD-WRT wiki said:The following chipsets can run both the normal (recommended- sometimes referred to as NEWD) and VINT builds.
* Buffalo WHR-HP-G54, WHR-G54S
* Linksys WRT54G v4.0
* Linksys WRT54GL 1.0 & 1.1
* All routers using Broadcom 5352 chipset
* All routers using Broadcom 4712 chipset (BCM4712) with wl0_corerev 5 or higher
