Hi all,
I bought my computer in 2009, and I'm thinking of possibly upgrading some components. I'm really wondering what's worth replacing/saving. I'm not looking to drop a ton of cash, so reasonable recommendations that provide a great performance vs price boost are what I'm looking for.
Here's my current setup:
My biggest and first hesitation is the motherboard. It was great in 2009, but it's now almost 2014. Only supports SATA II, USB 2.0, not sure what else is limiting on it. Should I replace this? If so, suggestions that would work in my case?
If I replace my motherboard, am I forcing myself into a cpu changeout. I know that my i7 model is discontinued, but surely it isn't a total underperformer, yes?
If I upgrade the motherboard, I'm guessing I may as well upgrade the RAM. I'd like to get 16GB. The RAM I have now has good stats (1600 9/9/9/24), but they're only 2gb modules. G-skill seems to be a common recommendation. Is there a noticeable performance difference between Ripjaw/Trident/Sniper? Or is there other memory I should be looking at?
As far as the hard drives, I'd like to get a SSD for the OS/Main programs, and I'll just keep my existing ones for everything else. SSD buying seems to be whatever is on sale of the main brands and you're probably good, yes?
850w power supply should still be good for awhile I assume.
Lastly, the graphics card... am I going to see a significant performance for price ratio if I upgrade it? What's a reasonable upgrade if so?
Thanks for any suggestions!
Code:
CM Storm Sniper Mid-Tower
Intel(R) Core(TM) i7-940 2.93 GHz 8M L3 Cache LGA1366
Asetek Liquid CPU Cooling System
FREEBIE_RM: None
RAID-0 250GBx2 SATA-II 3.0Gb/s 8MB Cache 7200RPM HDD
1TB SATA-II 3.0Gb/s 16MB Cache 7200RPM HDD
Asus P6T Deluxe Intel X58 Chipset SLI/CrossFireX Mainboard SAS Triple-Channel DDR3/1600 SATA RAID w/ eSATA,Dual GbLAN,USB2.0,IEEE1394a,&7.1Audio
6GB (2GBx3) DDR3/1600MHz Triple Channel Memory Module Corsair Dominator
CoolerMaster 850 Watts Real Power Pro
NZXT Sentry LX Aluminum High Performance Fan Control, Clock, & Temperature Display
NVIDIA GeForce GTX295 X2 1.7GB 16X PCIe Video Card
