The radiator and CPU waterblock came in today. I cleaned the radiator and waterblock perfectly, but (yes this is a stupid thing) forgot how to re-assemble the block. Which way (and side) should the bowing plate go?
http://www.swiftnets.com/products/APOGEE-GTZ.aspWhen you take the block apart, you'll find several parts. The delrin top with a delrin nozzle fitting into the top, a stainless bowing frame that sits around the perimeter and the copper base.
Here is a close up look at the underside of the GTZ top, the nozzle plate is a finely machined delrin peice that snugly fits into place.
The cold plate surface is topographically mapped to provide an optimized TIM joint with socket 775 & 771 processors. As a result, the Apogee™ GTZ requires a specific mounting orientation with respect to the CPU socket in order to optimize performance as illustrated below:
It's like this.........
I'll go with the Feser. I like the appearance of the Feser more anyways, I was just worried about it kinking. Now I just have to figure out what case. Would the Antec 1200 do well with the parts I'm getting?
http://www.ocforums.com/showthread.php?p=5896203#post5896203
I'm glad I asked then. So did I pick out the right clamps from McMaster?+1^. Methinks he got it off a sticky on XS, it was mentioned to use one. I read of hundreds of water builds by noobs and pros, no one uses a filter.
Here it is, same part #
http://www.xtremesystems.org/forums/showthread.php?t=54331
The sticky is almost 4 years old.... Looking at post dates helps. In the days back then, maybe. It was pretty DYI for almost everything back then, and possibly a good idea. Now? Rinse everything and clean the rad well is all you need really.
