- Apr 27, 2006
- Phoenix, AZ USA
Water Cooling Experts - Please Critique My First WC Layout In My Case
I just ordered the following water cooling setup from Performance-PCs.com and could use a little insight on how to best setup the loop:
Swiftech Storm CPU block
Swiftech MCP655 Pump
Alphacool Coolplex 10 reservoir
Danger Den Maze4 GPU block
Danger Den GT 240 radiator
8 feet of tygon tubing (1/2” ID)
10 reuseable plastic clamps
I’ve already got 2 Scythe S-Flex F series fans for the radiator. The other 120mm fans in my case are Yate Loons. One blows right onto the video card from the side window. The video card already has Zalman RAMsinks on it.
I’m going to use distilled water and I have a big jug of anti-freeze for my car with a ton of anti-freeze leftover. Should I look into getting some water wetter or is that not that important? Or should I get a different kind of coolant altogether? Eventually I may run it with some UV dye and a cold cathode tube, but I'm not worried about that at the moment. Any advice in that area though?
Here’s how I planned on doing the loop:
Pump --> CPU --> GPU --> Reservoir --> Radiator --> Pump
I plan to fabricate some sort of bracket to hold the Reservoir in place. Lancelot’s build made me decide I had to have the same res and put in a similar location.
If you can’t tell from the picture it’s all going into an original style Stacker case. The rest of the equipment is:
AMD 64 3200
DFI LanParty NF4 SLI DR (or whatever it’s called)
eVGA GeForce7900 GT
Any suggestions??
AMD 64 3200
eVGA GeForce7900 GT
Any suggestions??
